1. AC Question's Avatar
    the port in my phone wont work i tried charging it but something in it is broken. How much do you think it would cost to fix it?
    I have a Moto-X
    01-26-2015 07:53 PM
  2. op t must's Avatar
    A SWAG(scientific wild a** guess) could be $25 to $75. Take it to a qualified technician at your carrier's (ATT, Tmo, etc.) dealer or company-owned authorized service center for troubleshooting and an accurate estimate. Or get a recommendation for an independent/franchise repair place. That part may be a component in a larger assembly.
    I would try a different charger and or cable first. They do fail sometimes.
    Someone else on the forum may be able to tell you about whether the X can be charged wirelessly.
    Good luck and be aware that stretching a charging cable too far while your phone is connected can cause your charging port to fail.
    01-26-2015 08:37 PM
  1. Why does my phone reboot when using Bluetooth connection?
    Last Post: 02-18-2015, 01:06 PM
  2. Replies: 5
    Last Post: 02-01-2015, 01:59 PM
  3. How do I unlock my locked tablet that has a pattern lock?
    Last Post: 01-26-2015, 10:16 PM
  4. Replies: 0
    Last Post: 01-26-2015, 07:34 PM
  5. phone won't work
    Last Post: 01-26-2015, 07:13 PM
