1. AC Question's Avatar
    Today my phone was working fine and I had it charging as I was listening to music with it hooked up to an aux cord. The stereo turned off and now my phone won't turn on and all it shows is a solid red LED light. Sometimes it changes colors, with a mixture of red and magenta/purple. I let it charge for a couple hours and the light went light blue almost white. Still won't turn on but it was vibrating before when I had it charging. Did the stereo fry my phone? Like too strong of a surge went through the aux cord maybe? I've had previous problems with my battery, it drains quickly, so I hope that is just the problem. Can anybody shed some light? Thanks.
    01-26-2015 11:58 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It's probably more of a battery issue. If you were recently having issues with it, maybe it finally died. Try a new one.
    01-27-2015 12:57 AM
  3. chadw2014's Avatar
    My wife unplugged her galaxy s6 after charging and same thing happened. Screen went black and solid red light turned on.
    Heres how i fixed it: Press and hold Home, power, and volume down. A message came up about a "custom OS install". Press volume down to cancel. Phone should startup.
    08-03-2015 06:43 PM
  4. cdm1992's Avatar
    Thanks for that advice, Chad. I had the same issue and your method fixed the problem. Strangely, my phone turned out to be fully charged when it turned back on.
    10-04-2015 12:44 PM
  1. How do I Turn Off or Cancel my Lockscreens?
    By Tim Beckwith in forum HTC One M8
    Last Post: 04-19-2016, 06:07 PM
  2. Replies: 1
    Last Post: 03-25-2015, 03:07 AM
  3. Does the Samsung S5 warranty cover a broken screen?
    By dougfleis1 in forum Samsung Galaxy S5
    Last Post: 01-27-2015, 01:04 AM
  4. How do I change the camera modes on my Galaxy S5?
    Last Post: 01-26-2015, 11:35 PM
  5. Why won't my Samsung Galaxy Note II replacement charging port charge?
    By Mary Faith in forum General Help and How To
    Last Post: 01-26-2015, 10:50 PM
