1. Xana Magi's Avatar
    I'm kind of a noob, so bear with me here. A while back, the USB port on my rooted Nexus 7(2nd gen Wifi version) broke, meaning I had no way to connect to my computer. I thought I was screwed, but then I found out on an XDA forum, that its possible to connect to your computer over wifi. I tought it was great, until I realize the connection would be lost the moment I turned my tablet off(Something, which in hindsight, I should have realized earlier) Making it impossible to use stuff like the Nexus root toolkit. So is there anyway around this? Or am I actually screwed?
    Thanks in advance.
    And sorry for being a noob
    01-27-2015 10:15 AM
  2. Swapnil Jindal's Avatar
    you want a continuous stream of connection or just want to transfer files?
    01-27-2015 11:08 AM
  3. srkmagnus's Avatar
    Thanks in advance.
    No, unfortunately there isn't a way to achieve that since the Wi-Fi connection is being terminated once you shut off the device. What exactly are you trying to accomplish?
    Perhaps there's an alternative that will help you do that.
    01-27-2015 11:21 AM
  4. Xana Magi's Avatar
    Transfer some files... I think
    01-27-2015 11:45 AM
  5. Xana Magi's Avatar
    I was originally trying to update my tablet from 4.4.4 to 5.0.2. But I kept getting sent to twrp. After some digging, I found out that I needed to reinstall my stock recovery, which I did with flashify, but that also caused problems as whenever I tried to update, it would stop and give me an error message( the one with the red triangle). So then, I tried to unroot my device with the nexus 7 rooted toolkit, using adb over wifi, but it would always boot into boot loader mode, which then cut of WiFi connection.
    Also, sorry for replying so late, didn't expect such a quick to response to my question
    01-27-2015 11:51 AM
  1. Do people use Google Play Services?
    By Tatoeternietoe in forum Android Games
    Last Post: 02-07-2015, 08:30 PM
  2. Replies: 2
    Last Post: 02-02-2015, 05:31 PM
  3. Anyone here using Jaybird Bluebuds X?
    By Raymond Elliott in forum HTC One M8
    Last Post: 01-27-2015, 07:06 PM
  4. Why do I have problem with data connection sign?
    Last Post: 01-27-2015, 10:37 AM
  5. Replies: 1
    Last Post: 01-27-2015, 10:32 AM
