1. AC Question's Avatar
    I just got a galaxy s3 last night by the original owner, they didn't delete there personal information, so I did a factory reset, since then LED light wont turn on to show its taking a charge. The only way I can get it to do anything it to take out the battery, drain the excess power by pressing the power button,& replacing the battery. Instantly it vibrates once, and flashes to a black screen. In the upper left hand corner in blue it says Recovery Booting... after that it just shuts off
    Please help
    01-28-2015 10:25 PM
  2. Claude Speed's Avatar
    Maybe Factory Reset corrupted System data :-) Or Factory Reset is unusable :-) Is this phone rooted? If yes, then owner deleted factory reset data :-(
    belodion likes this.
    01-28-2015 11:11 PM
  3. belodion's Avatar
    Why on earth didn't the owner delete their personal data? Could you explain this further please?
    VDub2174 likes this.
    01-29-2015 07:54 AM
  4. dpham00's Avatar
    Return it to whoever you got it from, assuming that you bought it. If they opted for the carrier extended warranty then it should be covered by the carrier
    Sent from my Verizon Samsung Galaxy Note 4
    01-29-2015 08:02 AM
  1. How-to root may samsung galaxy discover 730m?
    Last Post: 01-28-2015, 10:21 PM
  2. Replies: 0
    Last Post: 01-28-2015, 10:14 PM
  3. Replies: 1
    Last Post: 01-28-2015, 10:00 PM
  4. pdf polarisviewer not opening on last viewed page
    By speedspeed in forum Samsung Galaxy Note 3
    Last Post: 01-28-2015, 09:38 PM
  5. Why does my tablet and phone scroll on its own?
    Last Post: 01-28-2015, 09:34 PM
