1. AC Question's Avatar
    Alarms: 44, Intent: android.net.connectivityservice.action.pkt_cnt_sample_interval_elapsed (Wakeups : 44 , 4.5 / h)
    The above is one of the "alarms" found under the category android using BetterBatteryStats app. This is the only culprit I suspected because there were nothing running in the background (checked Kernel and Partial Wakelocks)
    In the process tab,
    system_server used up 55%
    surfaceflinger used up 37%
    com.asksven.batterystats used up 40%
    com.android.systemui used up 26%
    com.android.settings used up 29%
    and others are below 10%, which I don't think there're the culprit.
    01-28-2015 11:27 PM
  2. belodion's Avatar
    Could you post a screenshot of the battery usage stats after a day's use, before you recharge? Also the expanded battery graph.
    01-29-2015 07:51 AM
  1. How is this with people with glasses?
    By dt81 in forum Virtual Reality Headsets
    Last Post: 02-14-2015, 01:33 PM
  2. Replies: 2
    Last Post: 01-30-2015, 12:55 PM
  3. Replies: 0
    Last Post: 01-28-2015, 11:21 PM
  4. Sprint S5 on Boost Mobile or another MVNO
    By G6_KidGogle in forum Samsung Galaxy S5
    Last Post: 01-28-2015, 11:12 PM
  5. Why can't I change my local profile on Galaxy S5?
