1. AC Question's Avatar
    I bought a Motorola Droid PRO+ Pro Plus MB632 unlocked on Ebay supposedly new. After only one month I woke up one morning, tried to turn it on and had no display. The phone was working however since I could hear various alert and screen lock sounds.
    I purchased a new display online and replaced it thinking the AMOLED display let go. No good, phone still the same. Any ideas before I toss it?
    Thanks, Mark
    01-29-2015 05:25 PM
  2. srkmagnus's Avatar
    Thanks, Mark
    Battery?
    If the device turns on then it may not be that, but it's worth a look before tossing. Also, if you bought new, and depending on how long ago you purchased, it could be covered under warranty? At least it may have been before you swapped the panel out.
    02-02-2015 01:04 PM
  1. How do I turn off alarm clock swoosh and click x to turn off?
    Last Post: 02-02-2015, 01:13 PM
  2. Readings and Status Bar
    By shey851 in forum Samsung Galaxy Tab Pro 12.2
    Last Post: 01-30-2015, 12:00 AM
  3. Replies: 1
    Last Post: 01-29-2015, 05:30 PM
  4. How do I recover my screen lock pin?
    Last Post: 01-29-2015, 04:12 PM
  5. Replies: 0
    Last Post: 01-29-2015, 03:03 PM
