1. AC Question's Avatar
    sprint galaxy note 3 notification sounds how do you change them from default for something that you would like to install as your notification sound how you change the default notification sound for your voicemail
    01-29-2015 07:05 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Review this article: Android 101: Adding your own custom sounds to Android events | Android Central
    Then open your Dialer/Phone app, tap Menu, then Settings, then Call Settings, then Voicemail, and select a new notification sound.
    01-29-2015 10:30 PM
  1. How do you close tabs on Gmail?
    Last Post: 01-29-2015, 10:34 PM
  2. How do I stop emojis from sending as mms?
    Last Post: 01-29-2015, 06:46 PM
  3. Why does Odin keep failing on my Galaxy S5?
    Last Post: 01-29-2015, 06:42 PM
  4. How do I get Gear Manager to show applications?
    Last Post: 01-29-2015, 06:38 PM
