How do I turn on head phones?
A
AC Question
how do i turn on head phones?
Droid Mini...
I don't get any sound !
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,524
4,663
113
Re: how do i turn on head phones?
Welcome to Android Central! How many different headphones have you tried? Are you sure the plug is in all the way? Sometimes, jacks are pretty tight, and people are a little hesitant to push it in all the way--you should feel or hear a click.
If multiple headphones don't work, check the jack to make sure there is no debris in there. Use a damp toothpick to root around, or a can of compressed air to blow it out. If the jack is clean, then it's probably broken.
taylorhudson5670
