1. Obaid Omar's Avatar
    [BOX]Why does my battery die so quickly on my LG Nexus 4?-screenshot_2015-01-30-09-44-03.png[/BOX]I'm using a Google nexus 4 (LG E960). the battery sometimes dies all of a sudden from 60% or higher to zero. I have attached a screenshot.
    01-30-2015 02:25 PM
  2. AlfBriggs's Avatar
    How long have you had the battery? Have these problems arisen after upgrading to Lollipop?
    01-30-2015 02:32 PM
  3. Obaid Omar's Avatar
    Yes, i remember this happened once before upgrading to lollipop. I have had the battery since I bought the phone in sept 2013. It's not a removable battery so I'm stuck with it. Should I attach the text of the bug report?
    01-30-2015 02:45 PM
  4. mbanu's Avatar
    a number of possible causes.
    screen brightness
    screen saver
    damaged battery
    resource intensive games / apps
    01-30-2015 04:11 PM
  5. Obaid Omar's Avatar
    screen brightness
    screen saver
    damaged battery
    I think, going by the causes you listed, it has to be a damaged battery because I haven't used anything else that you mentioned. No screen saver, no live wallpaper, no new apps and I dont play games. Screen brightness is set to adaptive. Never buying a phone with a non-removable battery again
    01-30-2015 05:38 PM
  6. GreenghostUvln's Avatar
    Try flashing a different ROM. My battery was going from 30 to 0 in minutes on the stock rom. I flashed cm and now I can hold 30% for at least 40-50 mins.
    Sent from my T-Mobile Nexus 4 LTE using Tapatalk
    01-30-2015 06:31 PM
  1. Does the LGL38C Optimus Dynamic use the 3.5mm jack?
    Last Post: 01-30-2015, 04:32 PM
  2. Replies: 1
    Last Post: 01-30-2015, 04:15 PM
  3. Replies: 1
    Last Post: 01-30-2015, 04:12 PM
  4. How can I install the 4g on my Samsung Galaxy S5?
    Last Post: 01-30-2015, 04:05 PM
  5. Why has my Kindle app stopped working since the OS upgrade?
    Last Post: 01-30-2015, 01:38 PM
