1. AC Question's Avatar
    hello,
    my name is Karan. I am using the Phone Samsung Galaxy Grand. My issue is sometimes I am using my phone it goes to hanging or it is stuck. Due to this I make my Phone switch off by Removing Battery. when I am switch on my Phone the battery will Drained or Emptying..
    I want to know the reason and how this issue removed from my Phone
    02-01-2015 05:25 AM
  2. dirisux's Avatar
    hello,
    do you have some battery manager installed?
    02-01-2015 08:54 AM
  3. belodion's Avatar
    Hello Karan. There are two things you can try which may help.
    1). Go to Settings, Storage, Cached Data, and clear the cache.
    2). Perform a Cache Partition wipe.
    There may also be a problem with your battery.
    Karan K Nair likes this.
    02-01-2015 09:13 AM
  1. Why is my 4g lte not working?
    Last Post: 02-01-2015, 09:43 PM
  2. How do I manage ANDROID 422 battery drainage?
    Last Post: 02-01-2015, 09:23 AM
  3. Where is the clipboard on my Motorola Milestone x?
    Last Post: 02-01-2015, 09:21 AM
  4. Where is the clipboard on my Motorola Milestone x?
    Last Post: 02-01-2015, 09:01 AM
  5. Why is there a lock on my screen when I turn on my phone?
    Last Post: 02-01-2015, 08:59 AM
