1. jrstrang's Avatar
    When the Samsung Galaxy Ace 4 rings I go to answer it but have to tap the Lock twice before I can answer it. Can this be removed?
    02-02-2015 08:53 AM
  2. anon8380037's Avatar
    Hello. Welcome to Android Central.
    I don't know if tapping twice is a feature of the Ace 4. You normally swipe the green tab to answer, do you mean you have to Swipe twice?
    On most Samsung models there is an option to answer with the Home button and end with the Power button.
    You would find these in Settings - (Device) - Accessibility - Answering/ending calls.
    Failing that you would need to contact the carrier or store.
    02-02-2015 09:14 AM
  3. Chrisdllej's Avatar
    HELLO i have the same problem. nothing helps ... seems that this phone have this problem and nothing can resolve. i tried everything..??? Help !!
    02-19-2015 07:05 AM
  1. Replies: 3
    Last Post: 02-02-2015, 01:02 PM
  2. Why does the Torch app remain on?
    Last Post: 02-02-2015, 09:56 AM
  3. Why won't my Irulu tablet AX101 power on?
    Last Post: 02-02-2015, 07:29 AM
  4. Replies: 0
    Last Post: 02-02-2015, 07:21 AM
  5. How do I give my backup pin on my G2 if I've never had one?
    Last Post: 02-02-2015, 07:06 AM
