A
AC Question
Samsung Galaxy Note II dialer problem.
Default dialer will not dial ext nbr.
After dialing a business number which uses an answering machine the default dialer will not dial an ext, it appears to add a number to any number input via the keypad ( press 2 and screen will show 21 or 28, etc.) everything after that becomes dead.
Worked until 4.4.2 update.
Does anyone else have this problem and have you found a solution? Thanks.
