1. AC Question's Avatar
    My Galaxy S4 got really hot while charging and would not retain a battery charge. If I tried to turn it on it would be stuck on the Sprint logo. Then it quit trying to charge the battery. I took it to a Sprint store. They checked the battery and it was good. They tried putting a new battery in the phone and it would not come on. Any suggestions?
    02-02-2015 06:34 PM
  2. MunichMen's Avatar
    Did you try to root?
    Posted via Tmobile Note 4
    02-02-2015 06:38 PM
  3. Rukbat's Avatar
    Evidently there's a short in the phone. Suggestion? Have it repaired. And I'd like to know how they determined that the battery was good. All they can determine is that it runs another phone for a few minutes. Even a battery so far gone that it's lost half it's life will do that - but I'd hardly call it a good battery.
    (Rooting doesn't cause or fix shorts.)
    02-02-2015 10:39 PM
  4. MunichMen's Avatar
    Agreed, something happened with my S3. When I tried my friends battery it seemed to function well.
    02-03-2015 12:02 PM
  1. Replies: 4
    Last Post: 02-04-2015, 10:24 PM
  2. Replies: 4
    Last Post: 02-03-2015, 01:03 PM
  3. Can I use straight talk on an LG G2 AT&T unlocked phone?
    Last Post: 02-02-2015, 10:54 PM
  4. Change Long-Press on Home Button Behavior?
    By stardomains in forum LG G3
    Last Post: 02-02-2015, 09:04 PM
  5. Any idea about Galaxy S5 Lollipop on U.S. Cellular
    By throssel in forum Samsung Galaxy S5
    Last Post: 02-02-2015, 06:42 PM
