A
AC Question
Phone only works when it connect to the charger.........!!!! plz help
my note is rooted.
few days ago i faced a wierd problem. My phone suddenly turn off. I tried to on it but it only show the "galaxy note gt n7000" screen for few seconds and off. Then i tried connect the charger and on it. then it on without problem & battery level shows 87% as it was when phone turn off. then i unpluged the charger and phone turned off immediately after i did so. Now my phone only works when it connect to the charger. But i put my galaxy s i9000's small battery to the note and on it. It works without any problem with that battery.
I checked my note's battery with my friend's note and battery works fine. I put his battery in to mine and turn on the phone. But the problem exists.
But with my galaxy s battery phone works fine.
when the problem happened my phone is in the CM12 lollipop beta 6 rom by Bauner.
I reflash it with stock rom using odin but didn't solve.
Plzzz help....
my note is rooted.
Plzzz help....
