1. daronmal's Avatar
    I tried factory resetting my phone (Droid Ultra) to fix an issue, but it wiped my music, so when i hooked it up to my PC, my PC didn't recognize it and nothing popped up like it usually did, then I realized my phone doesn't either, it just charges, doesn't notice its connects to a PC though.
    02-03-2015 09:18 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! When you connect via USB, do you get a USB connection notification at the top of the screen? If so, swipe down, tap the notification, and make sure MTP is selected.
    02-04-2015 12:54 AM
  3. daronmal's Avatar
    I dont, I have it selected in Settings > Storage > USB Computer Connection though. When I plug it in nothing pops up. I'm assuming its my phone since my PC is working fine and I know the USB port Im trying works, I've also tried every other USB port.
    02-04-2015 08:07 AM
  4. B. Diddy's Avatar
    Can you try a different USB cable?
    02-04-2015 09:23 AM
  1. Replies: 2
    Last Post: 02-04-2015, 06:34 AM
  2. Why doesn't my data connect to 4G LTE on my Galaxy Note 3?
    By Kevin Saunders in forum Ask a Question
    Last Post: 02-03-2015, 08:40 PM
  3. Why can't I connect my Irula tablet to wifi?
    Last Post: 02-03-2015, 06:02 PM
  4. Replies: 1
  5. Replies: 0
    Last Post: 02-03-2015, 02:41 PM
