1. AC Question's Avatar
    Yesterday my lg nexus 4 stopped receiving text messages. I can send text messages and make / receive phone calls.
    Any suggestions on how to fix?
    02-04-2015 08:22 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you already spoken to your carrier about it?
    02-04-2015 11:10 AM
  3. Kim Bagnall's Avatar
    I don't think it is the carrier as we have 4 nexus 4s in the family with the same carrier and mine is the only one acting funny
    02-04-2015 11:38 AM
  4. B. Diddy's Avatar
    Try wiping the cache partition: https://support.t-mobile.com/docs/DOC-5994
    02-04-2015 11:55 AM
  5. rakuqep's Avatar
    Open the message app in your phone.
    Select the conversation with a person from which you can't receive messages.
    Tap on menu button.
    Tap people & options.
    Now make sure that block option is not activated.
    If still you have same error than turn off your phone for 10 sec and turn it back on.
    After all these attempts if your problem is solved then its OK. If not, then check Lg Nexus 4 Manual for more options.
    01-24-2017 11:45 PM
  1. Replies: 10
    Last Post: 02-07-2015, 05:00 PM
  2. What is best app for MMS on the Nexus 5?
    Last Post: 02-04-2015, 11:15 AM
  3. Can you get more text bubbles?
    Last Post: 02-04-2015, 08:17 AM
  4. How to remove a name from multimedia texts sent?
    Last Post: 02-04-2015, 08:16 AM
