1. AC Question's Avatar
    Hi, as a seriously left-handed person, I keep swiping from right to left when I recieve incoming calls and accidentally rejecting them. is it possible to swap the left and right buttons so that left becomes Accept and right becomes Reject?
    02-04-2015 11:28 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? You could try the Force RTL Layout developer option. Go to Settings>Developer Options. If you don't see it, then go to Settings>About Phone, and tap Build Version 7 times. Now go back to Settings>Developer Options, and turn on Force RTL Layout. This reverses a lot of the buttons and other screen components so that it's Right To Left. I'm not sure if it affects the call accept/reject buttons, but it's worth a try. The rest of the phone layout might get kind of weird, though. You can easily turn the option off again.
    02-04-2015 12:18 PM
  1. How do I uninstall androidlost.com?
    Last Post: 02-04-2015, 12:42 PM
  2. Replies: 0
    Last Post: 02-04-2015, 10:59 AM
  3. How do I get rid of the double click to open an app?
    Last Post: 02-04-2015, 10:54 AM
  4. Is there a remote Bluetooth camera for Android?
    Last Post: 02-04-2015, 10:31 AM
