1. AC Question's Avatar
    Hi, I have a LG G3 and I noticed that the white bulb does not turn on, and when I take a picture on the dark, first turn on the yellow light but the pictures are dark!
    Someone can help me please!
    02-04-2015 04:26 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Sorry for the basic question, but the camera's flash is set to Automatic or On, right?
    Does your phone have a flashlight app? Try turning that on--if it doesn't work, the LED flash might be faulty.
    Esteban Valenzuela likes this.
    02-04-2015 07:31 PM
  3. Esteban Valenzuela's Avatar
    Yes, I tried with different flashlights apps, but only turn on one of the leds.
    Before the last software up date, it was working, now I have android 5.0 and it doesn't work; I don't know if may be a problem with the last actualization.
    If it's faulty, can I replace it?
    02-04-2015 08:13 PM
  4. Esteban Valenzuela's Avatar
    02-04-2015 08:19 PM
  5. B. Diddy's Avatar
    Hmm--the way you describe it, it sure sounds like it's related to Lollipop somehow. See what happens if you boot into Safe Mode: https://support.t-mobile.com/docs/DOC-11934
    02-04-2015 09:31 PM
  6. Esteban Valenzuela's Avatar
    It didn't work either.
    So I think it was a coincidence. There is anyway, a way to fix the bad bulb?
    02-05-2015 04:28 PM
  7. B. Diddy's Avatar
    If there's an easy way to do it by yourself, you'll probably find a video of it on YouTube. Otherwise, bring it to a repair shop or contact LG if it's still under warranty.
    02-05-2015 09:10 PM
  1. Ram usage in any version of android
    By eric002 in forum Moto X (2014)
    Last Post: 02-04-2015, 10:07 PM
  2. Why am I unable to answer calls?
    Last Post: 02-04-2015, 05:32 PM
  3. Contact not showing in My Contacts
    By jroberts268 in forum Samsung Galaxy S5
    Last Post: 02-04-2015, 05:11 PM
  4. Why do I receive a no signal sign after every call?
    Last Post: 02-04-2015, 04:57 PM
  5. Opinions on Mophie Juice Pack for the S5?
    By thatsomark in forum Samsung Galaxy S5
    Last Post: 02-04-2015, 03:50 PM
