1. AC Question's Avatar
    I am a little hard of hearing and sometimes cannot hear the phone ring
    02-07-2015 07:32 AM
  2. Rukbat's Avatar
    Use Ringtone Maker (or you can do this in Audacity on a PC, then copy the file back to the phone, if you want a better wuality ringtone). Open the ringtone file (green arrows on the right). Edit. Menu. Fade and Volume. The volume should be at the middle - 0. Move it all the way to the right. Save the file. It'll probably be distorted, but loud. (If you do it in Audacity you can increase it even more without distortion, but playing it back in the phone may cause distortion because the speaker can't handle the volume.) But in either case you'll hear the phone ring, which is what's important.
    02-07-2015 06:22 PM
  1. Cleaning the e989 screen
    By Roie Shalom in forum LG Optimus G
    Last Post: 02-08-2015, 02:16 AM
  2. Replies: 2
    Last Post: 02-07-2015, 07:09 PM
  3. How do I root my Micromax Unite2 A106?
    Last Post: 02-07-2015, 05:51 PM
  4. How can i detect pictures from Picasa a 4G LG phone?
    Last Post: 02-07-2015, 07:29 AM
  5. Replies: 0
    Last Post: 02-07-2015, 07:06 AM
