1. AC Question's Avatar
    from last 2 days, my battery is draining too fast. android system is using 41% of battery. I use power saving mode always. I don't turn on location. I use ultra power saving mode during night. but still full battery charge lasts only for 16-18 hrs. I noticed that my WiFi keeps disconnecting frequently. could that be the reason? but otherwise, is anyone having same problem with android system's battery usage?
    02-08-2015 04:24 PM
  2. Double Tap's Avatar
    I would try Gservicefix. You can download it from the Play store
    02-08-2015 04:26 PM
  1. Replies: 2
    Last Post: 07-29-2015, 10:59 PM
  2. My Android tablet will not turn on. What do I do?
    Last Post: 02-10-2015, 06:48 AM
  3. Where do I store music that I transfer from my PC?
    Last Post: 02-08-2015, 05:16 PM
  4. My S3 mini starts when i install the battery
    Last Post: 02-08-2015, 05:08 PM
  5. Replies: 1
    Last Post: 02-08-2015, 03:10 PM
