If the terminals match and the battery well is the same size, the battery will fit. Whether you can get a back to fit the S4 with that battery is another question. (And your charge time with a 7000mAh battery is going to be about 4 hours from 40% to 100%. The phone won't use higher charging current than it does for the stock battery.)
