1. AC Question's Avatar
    Hi. I have got a problem with my 5.0.1 Nexus 7 2013 wifi - when I have "wifi on during sleep" switched on, the battery life suffers greatly, as my tablet stays in sleep most of the time. When I switch it off, battery life is great but when waking up the tablet takes forever to connect to my home wifi. It changes from "saved" to "connecting" to "connected" for a few miliseconds and back to "saved" to restart the cycle. After a couple of minutes (sometimes shorter when I "help" it by clicking my wifi and "connect" a several times) it connects and everything works well. My phone and laptop never had issues connecting or using my home wifi, so I believe it's something with the tablet. Any ideas?
    02-09-2015 06:33 AM
  2. belodion's Avatar
    It may have a bad wifi antenna, causing it to keep searching for a wifi signal, thus draining the battery. It may be a weakness of the design, or a fault with your particular specimen, so you might want to have it tested, or do that yourself if you know how.
    02-09-2015 07:49 AM
  1. Replies: 4
    Last Post: 02-13-2016, 12:57 PM
  2. Why won't my OPO turn on or charge?
    Last Post: 02-17-2015, 05:59 PM
  3. Replies: 2
    Last Post: 02-17-2015, 05:29 PM
  4. Replies: 6
    Last Post: 02-11-2015, 05:16 AM
  5. Why is my data connection on my Grand 2 Vodafone so slow?
    Last Post: 02-09-2015, 07:29 AM
