1. AC Question's Avatar
    Hi,
    I will be spending about 3 months in the Bahamas and want to get a BTC SIM card to use their GSM and data network.
    It is my understanding after much searching that I can purchase a BTC SIM card and drop it in me Note 3 to get voice and text and probably data.
    I have these questions though:
    How do I get data access to work as well?
    It seems I have to edit the Access Point Name(s) - APN - on the phone to use the BTC data network but this is disabled on my Note 3.
    Will editing an APN get enabled with the BTC SIM card in the phone?
    Will I be able to use the phone WiFi hot spot with the BTC SIM card in the phone? If so, how because it will probably want to check the VZW subscription.
    Will tethering work?
    tia,
    paul
    02-09-2015 09:40 AM
  2. Tutsumi's Avatar
    Hi Paul,
    According to what I'm seeing, you should be able to get voice and data. If all goes well, the SIM should push settings to your device for you to install the APN. Make sure your Note 3 is internationally unlocked from Verizon, however.
    02-17-2015 02:31 PM
  3. Rukbat's Avatar
    Voice, text and LTE frequencies are compatible, so yes.
    Just with the proper APN.
    Go to Verizon. Have them enable International Roaming. If that doesn't unlock the APN (you should be able to add one), ask them to correct that. (You're in the store - when they enable IR, check the APN setting page.)
    If it does (it probably won't because the blocking is done at the carrier), download a free wifi hotspot or tethering app. But whether you can tether or not depends on BTC. If they don't allow it, or they charge extra and you don't want to pay, you can't.
    Tethering is using a wifi hotspot, so see above.
    02-17-2015 05:15 PM
  4. Bliss32's Avatar
    Thank you for the info.
    The local VZW francize has said that it is unlocked, but i'll go to a different, larger store and verify that and test the APN editing.
    I just want to get it right the first time because debugging this from the Bahamas would cost almost $2 / min voice.
    I always have PDAnet standing by for tethering and hot-spotting; I hope that works ok.
    tnx,
    p.
    02-21-2015 10:34 AM
  5. Tutsumi's Avatar
    *Sighs* I work there, yes, it's allowed.
    02-24-2015 01:22 PM
  6. Bliss32's Avatar
    Im here in Bahamas.
    Got a mrsimcard which worked. Needed btc help for data but that works now.
    Apn editing is allowed with btc sim card loaded.
    Cant get phone wifi hot spot to work. It wants to check vzw and can't.
    PdaNet and foxfi wifi hotspot demand phone lock pin which seems onerous.
    Thx for help and to mrsimcard.
    P.
    03-08-2015 01:45 PM
  1. Apps won't load on WiFi
    By Hana_H in forum Ask a Question
    Last Post: 10-21-2016, 01:45 PM
  2. Replies: 1
    Last Post: 02-09-2015, 02:31 PM
  3. Icon size on the Sony Xperia Z Ultra
    By net62957 in forum Ask a Question
    Last Post: 02-09-2015, 01:10 PM
  4. Replies: 1
    Last Post: 02-09-2015, 09:32 AM
  5. Usb 3.0 on UK galaxy S5
    By Simon Fortsch in forum Samsung Galaxy S5
    Last Post: 02-09-2015, 09:31 AM
