How do I block a contact or incoming call on my Kingelon n8000?
A
AC Question
kingelon n8000 contact block
Hot to block contact or incoming call? my Phone is Kingelon n8000
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
Re: kingelon n8000 contact block
Welcome to Android Central! I'm not familiar with that phone, but there are usually a few different ways:
1. Open your Phone/Dialer app, tap Menu, then Call Settings, and look for a call blocking option--this is dependent on the phone, so it's not always available. Also look through your system settings to see if there is something there.
2. Open your Contacts app, select the contact you don't want to hear from, tap Edit, then tap Menu, and check on "All Calls to Voicemail." You'll still get their messages, but the phone won't ring when they call.
3. Login to your account on your carrier's website and see if there are options for blocking there. You might have to pay an extra fee for that feature.
Chelsea rae
