1. AC Question's Avatar
    while coming of a call, the mobile rings and vibrate but as we shake it the mobile, iot automatically t urns into silent mode? whats the reason for this?
    02-10-2015 02:51 AM
  2. lsmachado's Avatar
    Have you checked your Settings under "Controls"? Under "Motions and Gestures", check whether "Mute/Pause" is on or off.
    Not sure what device you have, though. The setting mentioned above will mute incoming calls and alarms if the device is turned over or your palm is placed on the screen, at least on my Samsung Note 4, that is.
    Posted via the Android Central App on my bodaciously awesome Note 4!
    02-10-2015 08:11 AM
  1. advanced calling
    By lgbalfa in forum Motorola Droid Turbo
    Last Post: 02-10-2015, 12:09 PM
  2. I forgot my screen unlock code, how can I recover it?
    Last Post: 02-10-2015, 06:57 AM
  3. How do I get my HTC Desire 610 to connected to 3G?
    Last Post: 02-10-2015, 05:24 AM
  4. Replies: 0
    Last Post: 02-10-2015, 02:19 AM
  5. Lollipop Update for T-Mobile is out
    By Raghava Reddy K V in forum HTC One M8
    Last Post: 02-10-2015, 01:13 AM
