1. AC Question's Avatar
    How do i fix it?
    02-11-2015 11:26 AM
  2. Rukbat's Avatar
    You have a certain fixed amount of storage space. You've used most of it. The way to "fix" it is to remove some things - uninstall apps, move files to the SD card, etc. The fact that the phone starts with 512MB of storage means that you can't install too many current apps, because apps are larger these days than when the phone was made.
    02-11-2015 12:32 PM
  1. Why can't I close out the 'My Verizon' app?
    By Sharon Proctor in forum Verizon
    Last Post: 02-27-2015, 03:28 AM
  2. Replies: 11
    Last Post: 02-21-2015, 02:14 AM
  3. Why will only some of my SD card music show up on my phone?
    Last Post: 02-11-2015, 12:02 PM
  4. Issue with 4G on Xperia Z3 Dual Sim
    By skgwho in forum Sony Xperia Z3
    Last Post: 02-11-2015, 11:52 AM
  5. My 10" Irulu tablet won't turn on. The battery is charged.
    Last Post: 02-11-2015, 11:13 AM
