1. AC Question's Avatar
    If not, can I expect this problem to be fixed or is my tablet just useless unless I wipe it and downgrade?
    02-11-2015 02:44 PM
  2. belodion's Avatar
    Have you tried a Cache Partition wipe, or even, with everything that you want to keep backed up first, a Factory Reset?
    02-11-2015 03:15 PM
  3. Kristina Burgess's Avatar
    I can try a Cache Partition wipe if it's not too complicated. As for backing everything up, I am mostly concerned about my setup (screens, folders and such), which takes a very long time to do. I am guessing there is no easy way to do it. Either live with it or put in the work...?
    02-11-2015 04:21 PM
  1. Replies: 1
    Last Post: 02-11-2015, 05:46 PM
  2. Replies: 1
    Last Post: 02-11-2015, 05:24 PM
  3. Why won't my Galaxy S5 connect to my iMac?
    Last Post: 02-11-2015, 04:18 PM
  4. Replies: 1
    Last Post: 02-11-2015, 04:13 PM
  5. Replies: 1
    Last Post: 02-11-2015, 03:20 PM
