1. AC Question's Avatar
    I have held it down and squeeze it with my fingers as suggested by Samsung...no luck.
    02-12-2015 05:51 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is it a widget with various toggles? What happens when you press and hold it? Does it allow you to move it at all? What about any other shortcuts or widgets on the homescreen--can you long-press any of them in order to move them?
    02-12-2015 04:52 PM
  1. Should I upgrade my new Galaxy Note 10.1 2014 to Kitkat?
    By Lindsay19 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 02-19-2015, 02:21 PM
  2. How do I stop app photos from automatically adding to the Gallery?
    By RockDesk in forum Android 5.0 Lollipop
    Last Post: 02-12-2015, 05:16 PM
  3. How fo zi specify/select 5Ghz HotSpot in 4.4.2?
    Last Post: 02-12-2015, 05:06 PM
  4. Replies: 0
    Last Post: 02-12-2015, 05:36 AM
  5. Should I upgrade Note 10.1 2014 to Kitkat?
    Last Post: 02-12-2015, 05:29 AM
