1. AC Question's Avatar
    The phone will connect to 4G but wont connect to LTE. I've gone through the APN settings with the carrier and confirm they're right. My SIM was taken from a Note 3 that connected to Rogers LTE fine.
    02-13-2015 09:04 AM
  2. Golfdriver97's Avatar
    I tried checking your device bands against what Rogers uses, and they look like they match. Have you tried taking it into a carrier store?
    02-13-2015 09:16 AM
  3. BTsats's Avatar
    Hey Golfdriver97 thanks for checking, I tried calling Rogers and we went through the APN settings and they're all set up correct. They mentioned that it may need to be enabled in the boot loader or something along those lines. I then tried calling Samsung direct and im pretty sure the guy was reading the landry machine manual.
    02-13-2015 09:38 AM
  4. Golfdriver97's Avatar
    Unfortunately, I can't help with that. I haven't messed with anything like that before.
    02-13-2015 09:44 AM
  1. Why is my Galaxy Note 4 saying i'm docked?
    Last Post: 02-13-2015, 09:24 AM
  2. Replies: 1
    Last Post: 02-13-2015, 09:09 AM
  3. How do I remove a default Samsung Galaxy S3 pin code?
    Last Post: 02-13-2015, 09:08 AM
  4. Why isn't my ear piece working when the wifi is on?
    Last Post: 02-13-2015, 09:06 AM
  5. Note 4 Replacement Camera Lens
    By jj482 in forum Samsung Galaxy Note 4
    Last Post: 02-13-2015, 08:32 AM
