1. AC Question's Avatar
    Hi i have just upgraded to lollilop and now my sd Card san disk is no longer read. i Ave tried to nfts instead of exfat 32 but still wont work. Have you had the same Problem? do you have a solution?
    02-13-2015 05:24 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Although system updates are not supposed to affect the microSD card, I've seen posts here from people whose cards got corrupted or wiped with the system update, so it's usually a good idea to unmount and remove the card beforehand.
    I don't think any Android device has native NTFS compatibility. Some support exFAT, but the most widely compatible filesystem for SD cards in Android devices is FAT32.
    02-14-2015 12:49 AM
  1. Replies: 8
    Last Post: 02-17-2015, 08:01 AM
  2. Can someone explain my ZTE Prelude 2 text feature.?
    Last Post: 02-15-2015, 11:51 PM
  3. How do i get 5.0 update for lgoptimusl90
    By Dante James in forum Ask a Question
    Last Post: 02-14-2015, 12:50 AM
  4. Replies: 1
    Last Post: 02-13-2015, 05:17 PM
  5. Is there an app like MotoCast for the Galaxy S4?
    Last Post: 02-13-2015, 05:07 PM
