A
AC Question
So, my phone, which is the THL T6 PRO, has the charging light and it was charging perfectly fine up to 65% and then it started draining down. The phone is conected to a plug. Is this because of the battery?
Before the charging port was kind of loose but I managed to fixed that as of now the charger isn't loose.
