1. AC Question's Avatar
    Hi I have a WD TV live that I use to play movies off my hard drive. I don't keep it connected to any network and just use thumb drives or my external HDD. Recently my computer has died so I started downloading movies on my smartphone with a torrent app. Id like to be able to plug my phone into the media player with a USB cable and play movies off it or transfer the movies to my main HDD off my phone. When I plug the smartphone into my WD TV live I get the message saying " unable to create media folder on read only storage" or something like that. So I'm just looking for a easy basic way to use my smartphone as basicly a thumb drive to play movies off of. I know I could go buy a thumb drive that can connect to my phone or a hml cable but I'd rather not spend more money. I'm using a Galaxy Note 3 running CM12.
    02-15-2015 04:39 PM
  1. Is it possibe to hide SD card files?
    By slaffa in forum Samsung Galaxy Tab S 10.5
    Last Post: 07-20-2016, 04:13 PM
  2. Learn from my mistake, if you sign up CHECK YOUR EMAIL
    By Bresarek96 in forum OnePlus One
    Last Post: 02-18-2015, 02:16 PM
  3. What is wrong with my battery?
    Last Post: 02-15-2015, 05:14 PM
  4. How to uninstall towelroot from my lg optimus l90?
    Last Post: 02-15-2015, 05:11 PM
  5. Replies: 1
    Last Post: 02-15-2015, 04:33 PM
