1. AC Question's Avatar
    Quando tento procurar as aplicações do gear s conforme orientado no manual, não aparece nada e nem mesmo o display rola nem da esquerda para direita nem de baixo para cima. Não encontro nenhuma aplicação. Tudo desapareceu misteriosamente depois de um mês de uso do gear S. Entretanto o chip funciona. Faço chamadas e recebo chamadas. Só não ligo ou partilho com o Note 4.
    02-16-2015 12:28 AM
  2. belodion's Avatar
    [Goog.Tr.]:
    When I try to look for applications draggin as directed in the manual, nothing appears and even the display scrolls or from left to right or from the bottom up. I find no application. All mysteriously disappeared after a month of use of the gear S. However the chip works. Make calls and receive calls. Just do not care or share with Note 4
    02-16-2015 07:14 AM
  1. Replies: 3
    Last Post: 03-21-2015, 11:22 PM
  2. Replies: 1
    Last Post: 02-16-2015, 07:22 AM
  3. What happen to Facebook app on gear I don't see it in app. any more
    By zaydabarber in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 02-15-2015, 10:16 PM
  4. How do I get the S Note apk (unsigned)?
    By dadathepanda in forum Samsung Galaxy Note 3
    Last Post: 02-15-2015, 08:27 PM
  5. Replies: 1
    Last Post: 02-15-2015, 06:26 PM
