1. AC Question's Avatar
    My old Droid charger broke. Will my Galaxt 3 charger fit?
    02-16-2015 07:41 PM
  2. Rukbat's Avatar
    Yes.
    Will it charge the Droid as fast as the Droid charger did? That depends on the output current of the Droid charger and the ourput current of the Galaxy 3 charger. Look at the label (it's usually small enough to need a good light and a magnifying glass, and I have 20/20 vision) and look for the line labeled Output. Look for the A part. It'll be 5 Volts or 5V (or close to 5, maybe 5.2), and some number of A or mA or Amps. If the Galaxy charger can supply less current (Amps) than the Droid charger, it'll charge slower. (1 Amp is 1,000 mA, so if one is in Amps and the other in mA, you can move the decimal point 3 places.)
    But any microUSB charger will charge any microUSB phone (or tablet or mp3 player - or any device, really). It's the voltage that's important, and they're all nominally 5 Volts.
    02-17-2015 12:07 AM
  1. Why am I not receiving text messages on my Note 4?
    Last Post: 04-15-2015, 09:08 PM
  2. Strange picture on my lock screen
    By Ilfracombe in forum Google Nexus 5
    Last Post: 02-17-2015, 10:08 AM
  3. Can I use a Sprint Galaxy S4 on Straight Talk?
    Last Post: 02-17-2015, 12:11 AM
  4. Why isn't my S3 mini sd card recognizing my laptop?
    Last Post: 02-16-2015, 10:01 PM
  5. Replies: 1
    Last Post: 02-16-2015, 07:19 PM
