1. AC Question's Avatar
    I took the back off and took the battery out cause my phone was glitching or something...but know i cant turn it on, i think my power button is jammed how do i fix it..?
    02-16-2015 11:34 PM
  2. Rukbat's Avatar
    The button doesn't move in when you press it? You can try gently prying one end up with a wooden toothpick. (If the toothpick breaks you're applying more pressure than it should take if it's just jammed.) If that doesn't work it's going to take a trip to the repair shop.
    02-17-2015 12:31 AM
  1. Why is my Android log slow and always hangs?
    Last Post: 02-17-2015, 12:34 AM
  2. Why won't my Samsung Galaxy Tab 4 10.1 charge at all?
    Last Post: 02-17-2015, 12:33 AM
  3. Replies: 1
    Last Post: 02-16-2015, 11:22 PM
  4. Replies: 1
    Last Post: 02-16-2015, 11:20 PM
  5. Where can i find a rooting for my android?
    Last Post: 02-16-2015, 11:04 PM
