1. AC Question's Avatar
    After upgrade to 5.0 via the System Update function of the phone, not rooted, it drains very fast and phone is warm.
    02-17-2015 12:40 PM
  2. belodion's Avatar
    Try a Cache Partition wipe, and if no go, and your personal data is backed up, a Factory Reset.
    02-17-2015 01:25 PM
  3. Kevin Garnier's Avatar
    You're kidding, right? Update my phone to the new OS, Lollipop and now the battery drains and the only advise is to reset to factory? Is that the stance of Android and Samsung? What a hassle.
    02-19-2015 01:43 PM
  4. Kevin Garnier's Avatar
    The factory did not work. I went from 100% to 16% in 2.45 hours. Any other ideas to stop the drain?
    02-20-2015 03:10 PM
  5. BR34KF4ST's Avatar
    best to make back to kit kat
    02-22-2015 01:22 AM
  1. DCM Provider Android Lollipop :: Battery Drain
    By NeilWhitear in forum Samsung Galaxy Note 4
    Last Post: 01-31-2017, 08:03 AM
  2. Sony Smartwatch 3 - Battery Chart Question
    By Stwutter in forum Sony Smartwatch 3
    Last Post: 02-23-2015, 05:35 PM
  3. battery life
    By donebrasko in forum Samsung Galaxy Note 4
    Last Post: 02-19-2015, 11:08 PM
  4. Why is my battery draining so quickly?
    Last Post: 02-17-2015, 07:57 AM
  5. Replies: 1
    Last Post: 02-16-2015, 07:34 PM
