How can I use my Bluetooth to listen to books via audio (I have a Samsung S4 and a Jabra go pro 6470.)?
A
AC Question
I have a samsung S4 and a Jabra go pro 6470.
The bluetooth works great for phone calls, however, I would like to use it to listen to books via audible. Not sure if this can happen and I can't seem to figure it out. The audible app states it can read bluetooth signals.So how can I tell it to use blue tooth headset vs the phone speakers
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,736
113
Re: I have a samsung S4 and a Jabra go pro 6470.
Welcome to Android Central! Go to Settings>Bluetooth, and tap the Jabra listing. Do you see a checkbox for Media Audio? If not, and you only see Phone Audio, then the Jabra only supports phone calls.
