1. AC Question's Avatar
    The bluetooth works great for phone calls, however, I would like to use it to listen to books via audible. Not sure if this can happen and I can't seem to figure it out. The audible app states it can read bluetooth signals.So how can I tell it to use blue tooth headset vs the phone speakers
    02-19-2015 02:57 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Go to Settings>Bluetooth, and tap the Jabra listing. Do you see a checkbox for Media Audio? If not, and you only see Phone Audio, then the Jabra only supports phone calls.
    Rukbat likes this.
    02-19-2015 11:22 PM
  1. Replies: 2
    Last Post: 02-20-2015, 07:39 AM
  2. Replies: 1
    Last Post: 02-19-2015, 03:39 PM
  3. Replies: 0
    Last Post: 02-19-2015, 02:40 PM
  4. Replies: 1
    Last Post: 02-19-2015, 02:37 PM
  5. Replies: 0
    Last Post: 02-19-2015, 02:26 PM
