1. AC Question's Avatar
    I cann,t get my note pro 12.2 otg usb 3 cable to work with lexar 16gb jump drive or any memory stick should i use a standard otg cable or any ideas.Thanks
    02-20-2015 09:04 AM
  2. srkmagnus's Avatar
    Try another cable and see if that works. If not, are you sure that the drive is properly formatted to be read by the Note Pro?
    02-20-2015 09:24 AM
  1. CF-Auto-Root on the Verizon Note 4 [SM-N910V]
    By bpeter in forum Samsung Galaxy Note 4
    Last Post: 03-24-2017, 07:39 AM
  2. galaxy s5 andriod does not seem to work well, how to fix
    By Martin Green2 in forum Samsung Galaxy S5
    Last Post: 02-20-2015, 04:21 PM
  3. Replies: 1
    Last Post: 02-20-2015, 08:57 AM
  4. USB Hardware Failure?
    By cotys in forum HTC One Rooting, ROMs & Hacks
    Last Post: 02-20-2015, 08:39 AM
  5. note 2 data on e. cant get h or h+.
    Last Post: 02-20-2015, 08:07 AM
