1. co1981's Avatar
    Hey guys, I have had my phone for over a year and have had no problems till now.
    Last week my phone did some update (am running 4.2.2) and now my phone will not stay/connect to the wifi at work unless I am in an immediate hotspot. I have tried numerous fixes including clearing the cache in recovery mode and even a full factory reset. WiFi works fine at home and other places. My fellow coworkers are able to connect no problem.
    Any advice?
    02-20-2015 02:20 PM
  2. Rukbat's Avatar
    Check the Advanced settijngs in Wifi.Keep wifi on during sleep, Auto network switch and, if you have it, Avoid weak signals.
    Wifi should Alwways be on during sleep (or it'll disconnect when the screen goes to sleep [which usually puts the phone to sleep]), it shouldn't automatically switch to mobile data and it should stay on a signal even if it gets weak. So Always on Keep, no check in Auto switch and no check in Avoid weak signals.
    02-20-2015 07:01 PM
  3. co1981's Avatar
    Mine doesn't have the "avoid weak signal" option, but that sounds exactly like what is happening. Any ideas on where I could change that kind of setting?
    02-20-2015 10:54 PM
  4. J Boyd's Avatar
    I am having the same issue.
    J Boyd NotePRO
    02-21-2015 08:17 AM
  5. co1981's Avatar
    Please let me know if you find a fix. I'm still searching...
    02-21-2015 01:32 PM
  1. How can i downgrade to KitKat? Lollipop sucks!
    Last Post: 02-20-2015, 07:08 PM
  2. Replies: 1
    Last Post: 02-20-2015, 06:25 PM
  3. Replies: 2
    Last Post: 02-20-2015, 06:15 PM
  4. Why can't I access photos on my S5?
    Last Post: 02-20-2015, 01:58 PM
  5. Why isn't my screen rotating?
    Last Post: 02-20-2015, 01:52 PM
