1. AC Question's Avatar
    i have an 50 000 mAh external battery with two outputs (one 2.1 A and one 1 A )and tryied to charge my note 4 but with no succes. the led's from external battery shows me that the phone is charging, but the phone shows me that it doesnt. ive tryied on another samsung, i got the same result, tryied with other phones, sony, htc etc and it works. is there something that i should do in the settings on the note 4? thank you
    02-22-2015 01:39 PM
  2. Rukbat's Avatar
    No, the phone doesn't car what the source is - battery, wall charger, solar panel - 5 volts will charge it.
    Are you sure the external battery is fully charged (at least overnight)? An almost discharged battery will show that th phone is plugged in, but won't have enough current available for the phone to charge.
    02-22-2015 04:21 PM
  1. Battery usage decreased by half, 60% screen
    By jboggs in forum Samsung Galaxy S4
    Last Post: 02-24-2015, 10:45 AM
  2. Why is my Galaxy S4 having difficulty charging?
    Last Post: 02-22-2015, 09:19 PM
  3. How do I gain root access to my SHARP AQUOS?
    Last Post: 02-22-2015, 06:33 PM
  4. what if i forgot my backup password for fingerprint lock
    Last Post: 02-22-2015, 02:30 PM
  5. What brand for tempered glass? Need some help from geeks
    By Pancho Maran in forum General Help and How To
    Last Post: 02-22-2015, 01:20 PM
