1. AC Question's Avatar
    I don't know if is a problem with the lollipop upgrade or is a harware problem when i make a Phone call, hear a noise at the top Headphones. And if I use a wire Headphones Just I can hear the rigth side speaker
    02-22-2015 02:22 PM
  2. Rukbat's Avatar
    The phone is under warranty. You've already spent as much time as I would on a warrantied phone, just by posting the question.
    It could be a popped capacitor on the motherboard, it could be a defective earphone jack, it could be a bug in Lollipop - it could also take hours to find what it is.
    Back everything up, bring the phone to your carrier and ask them to please fix or replace it. (If you don't always keep everything backed up [which you should - never can tell when the phone slips out of your hand into a sewer grating], backing it up is more time than you should be spending on a warrantied phone with a covered problem.)
    02-22-2015 03:47 PM
  1. What watches have the ability to read heart rate?
    By Justin Cardwell in forum Android Wear
    Last Post: 02-26-2015, 09:49 PM
  2. How do you turn on your Nexus 7 if it is frozen completely?
    Last Post: 02-22-2015, 09:10 PM
  3. How to turn on a nexus 7 if it is frozen completley ?
    Last Post: 02-22-2015, 04:04 PM
  4. How will an S5 Active hold up in a sauna?
    Last Post: 02-22-2015, 03:57 PM
