A
AC Question
Galaxy S5 problems after new SD card
Okay so recently my 16 GB SD card was full on my galaxy s5. So i ordered a Samsung evo 64 GB micro SD card. I put the 16 gb card into my computer and copy and pasted all the data over to my computer. At first it keep failing, until i copied each folder at different times, it wouldnt let me do them all at once. Then i copied the files from my computer to the 64 gb sd card. All of the videos were resized super small. So i deleted the 64 gb card and tried again. This time every picture and video were black. I deleted and tried again and it turned out like the first time, except i lost some recent pictures. I settled with the small videos to avoid losing more pictures. Soon after installing the 64 GB sd card (after i moved most of my apps to the sd card) a couple apps on my sd card would so up as if the sd card was removed ( a clear picture of an sd card). I tried to transfer them back to phone memory but it said they were not installed. So i uninstalled them from the play store and reinstalled them. Then i would get random messages like "com.facebook(blahblahblah) stopped working". So i would go into my app manager and would uninstall that to get it to stop popping up. This caused no apparent problems. Other apps would do it and i would do the same thing. Everything worked good for a couple weeks. Now my phone is giving me messages "contacts stopped working" every now and again. I have not done anything to try to stop this, i dont wanna loose my contacts. My internet (stock app) tabs keep crashing. They crash every 5 seconds and i cant do anything on the internet because it is so annoying. I tried clearing the cache, nothing. My battery doesnt hold as long as it used too and my phone is starting to run really slow and lags a lot. Ive come to the conclusion that a factory reset is my only solution. Should i format my sd card also after i reset? How should i save the data on my sd card and not run into problems like before. Thanks for your help, Kyle.
