1. AC Question's Avatar
    Galaxy Grand i9082 battery falls from 50 to zero in 2 or 3 minutes. I tried changing the battery. Still it doesn't work
    02-24-2015 12:25 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Probably a failing battery. Try a new one.
    02-24-2015 02:54 PM
  3. Rukbat's Avatar
    Then either you have extremely bad luck and replaced it with a shot battery (as likely as getting hit by a piece of debris falling off an alien space ship) or there's a short somewhere in the phone. Unfortunately, it probably will cost more to find the problem and fix it than it will to replace the phone.
    02-24-2015 03:48 PM
  4. B. Diddy's Avatar
    Sorry, I must have totally missed that the OP said he already tried changing the battery!
    02-24-2015 04:47 PM
  1. Resetting Galaxy Note 2014 to initial ("clean") state?
    By Phitz in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 02-25-2015, 08:08 AM
  2. How to check if unlocked?
    By angelisawesome in forum Samsung Galaxy S5
    Last Post: 02-24-2015, 03:58 PM
  3. Does T-Mobile need to give an unlock code for the Nexus 5?
    Last Post: 02-24-2015, 02:57 PM
  4. Replies: 2
    Last Post: 02-24-2015, 12:33 PM
  5. Replies: 1
    Last Post: 02-24-2015, 12:06 PM
