1. AC Question's Avatar
    What is it that measures the temperature of the battery on the Samsung Galaxy S5, it has not temp / humidity sensor such as S4 had?
    I sometimes get this message when I try to charge, charging paused battery temperature too low. Also get temperature too low when I try to use the photo light on camera.
    I have tried to replace the battery and I have downloaded several apps to test sensors in the phone, and it displays battery temp -30C.
    someone who knows what measure this and what part i must replace fixed this! ?
    Thanks..
    02-24-2015 01:48 PM
  2. AndroidHabit's Avatar
    -30C is Celsius so your battery is very cold at -22F Fahrenheit.
    A good battery's temperature should be around 77F.
    Did you replace the battery or "tried" to?
    If you did replace the battery then maybe a factory reset will help, if not then get a warranty replacement.
    02-24-2015 07:09 PM
  3. anon8380037's Avatar
    If you have a carrier free phone there are sensor tests with *#0*#
    Try the well recommended GSam battery app which has a temperature reading.
    02-24-2015 07:41 PM
  1. Better battery life on 4G
    By Dale1401 in forum Moto G (2013)
    Last Post: 02-25-2015, 01:03 AM
  2. Replies: 3
    Last Post: 02-24-2015, 04:47 PM
  3. Replies: 1
    Last Post: 02-24-2015, 07:40 AM
  4. How do I disable the OS services that uses too much data?
    By allnamesaretaken in forum Ask a Question
    Last Post: 02-24-2015, 01:36 AM
  5. What are the best app for battery saving?
    By Deshiandroid in forum Ask a Question
    Last Post: 02-24-2015, 12:27 AM
