1. AC Question's Avatar
    i am using moto g since 4 months . it was very good in browsing when i first time use it. but now it is going slower while loading web pages on crome. similar is the problem with you tube. i am just bored while surffing. same is the problem on wifi . i have downloded clean master for clearing ram but it was also unhelpful. plz help me
    02-24-2015 10:30 PM
  2. Rukbat's Avatar
    First uninstall Clean Master - it slows the phone down. Anything from Cheetah shouldn't be on your phone. (Clean Master does exactly the opposite of what Android's trying to do. Anyone who understands how Android works doesn't write an app to remove apps from RAM.)
    Second, Clear the system cache (in Storage, in Settings). See if that speeds things up. Also, go to speedtest.net and see what your download speed is. If it's slow, the problem isn't in your phone, it's inn your internet connection. If you're having the problem using mobile data, talk to your carrier. IF it's happening on wifi, talk to your internet provider.
    02-24-2015 11:34 PM
  1. Is 360 Security Qihoo a virus or trogen?
    Last Post: 02-25-2015, 09:24 PM
  2. Can I get some help with my Android Device Manager?
    By Pleiades33 in forum General Help and How To
    Last Post: 02-25-2015, 03:36 PM
  3. Replies: 4
    Last Post: 02-25-2015, 02:20 PM
  4. Replies: 1
    Last Post: 02-24-2015, 11:41 PM
  5. Replies: 1
    Last Post: 02-24-2015, 11:39 PM
