1. hondafan6's Avatar
    My Galaxy S5 is only 6 weeks old and the battery drains really fast. I don't have any applications in the background running ,my Bluetooth is turned off and I even turn off my wifi while I'm at work and my battery life is still bad. Anyone else? Suggestions?
    02-25-2015 07:16 AM
  2. Thom89's Avatar
    Install gsam battery monitor that should give you an idea, also I've found the lollipop update drains my battery like mad even with a factory restore but others will argue this fixes it
    02-25-2015 07:29 AM
  3. hondafan6's Avatar
    Thank you Thom89
    02-25-2015 05:37 PM
  1. How do I cancel the Lollipop update installation on my S5?
    Last Post: 04-11-2015, 03:15 PM
  2. Replies: 3
    Last Post: 02-25-2015, 11:51 AM
  3. My Samsung Galaxy S5 is not saving my Afrikaans words.
    Last Post: 02-25-2015, 07:33 AM
  4. Replies: 1
    Last Post: 02-25-2015, 02:02 AM
  5. Problem with web browsing on new S5
    By NGW in forum Samsung Galaxy S5
    Last Post: 02-24-2015, 11:30 PM
