1. snakey#AC's Avatar
    Anyone know what the icon is just to the left of the 4G is? Been coming on quit a bit last few days and it's killing my battery on my M8..
    02-25-2015 01:33 PM
  2. dpham00's Avatar
    I believe it is gps
    Sent from my Verizon Samsung Galaxy Note 4
    02-25-2015 01:38 PM
  3. Cdxn85's Avatar
    Yeah that appears to be GPS. It will become actively seeking your location when opening any app the uses location, such as maps or Facebook etc. You could go to location settings and either disable or enable power saving mode which should help your battery out!
    03-04-2015 03:42 AM
  4. neilmceachin's Avatar
    It's gps. You have an app running that is requesting the gps location if the phone. Find the app and change is settings, or you might have to delete it if it keeps giving you problems. Don't forget to check the battery usage graph in your android settings, it can help point you in the right direction. My location is always on and I have not had any problems so far (Although I have had to get rid of several poorly written apps in the past)
    03-09-2015 09:32 PM
  1. Replies: 750
    Last Post: 02-19-2016, 08:20 AM
  2. Why are my apps turning notices on by themselves?
    Last Post: 02-26-2015, 10:56 AM
  3. Replies: 1
    Last Post: 02-25-2015, 02:54 PM
  4. Is there a way to get the Verizon apps off my phone?
    Last Post: 02-25-2015, 01:33 PM
  5. Why does my HTC One keep kicking me out of my group messages?
    Last Post: 02-25-2015, 01:04 PM
