1. AC Question's Avatar
    When im using my tablet, at about 75% battery, the screen starts flashing on and off quickly, and shuts down. it wont turn back on, unless I plug it in. and if I plug it in, turn it on, and unplug it again, it will flash and die again right after booting up. This problem occurred last night when I was simply watching YouTube. It works just fine when its above 75%. but it dose that thing when its under 75%.. I thought about doing a hard reset but I don't want to delete all my apps and go back to factory. Is it possibly a virus, or a battery connection issue like with the galaxy gab 2 and 3?
    02-25-2015 10:44 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which device do you have? It could be a bad battery, or a motherboard problem. I doubt it's a virus.
    02-26-2015 12:27 AM
  1. Replies: 13
    Last Post: 11-19-2015, 11:45 PM
  2. How can i get my Phone to blackout with a wallet phone case?
    Last Post: 02-25-2015, 10:00 PM
  3. How can I get my Touch working again?
    Last Post: 02-25-2015, 09:58 PM
  4. How do I get more than three movies on my 64 gb sd card?
  5. How do I get rid of a ECOU pop up notification on my phone?
    Last Post: 02-25-2015, 09:41 PM
