1. AC Question's Avatar
    I have a Samsung pro note 12.2 and when I plug my Samsung M3 portable 1T it reads 'blank USB card' and will not open it. It works on my laptop and didn't know if I could get it to work on my table.
    Any help?
    Thanks
    02-26-2015 06:55 AM
  2. hallux's Avatar
    Are you also plugging the drive into another power source? A spinning HDD will draw more power than it would be able to get from an OTG cable. I don't think my Acer A500 would even support a spinning HDD off it's USB-A port. I guess I could try it tonight if I remember but I'm not using that device anymore.
    02-26-2015 08:42 AM
  1. How do I root a Samsung Note 4 from Verizon?
    Last Post: 10-16-2016, 09:33 PM
  2. Is it possible to sync text messages from my S3 to email?
    Last Post: 02-26-2015, 12:35 PM
  3. Replies: 1
    Last Post: 02-26-2015, 07:57 AM
  4. Can I clear suggested phrases on my Galaxy S3 and Tab 3?
    Last Post: 02-26-2015, 07:43 AM
